PC V1.0 Build
http://pcpartpicker.com/p/2aF3z
Here I have my first attempt at building my first PC. This computer will mostly be used for gaming, and the odd college paper here and there.
 Mostly I'm looking to know if this rig will run, and if so how well, OR if it's going to blow up and cause my place to burn down... I am open to any suggestions But I really enjoy the look of this case Plus I get to put in 4 200mm fans, and that isn't something I'm willing to give up!
For other people to see your build list you need to copy the "permalink" under "System Build", its right below the actual button for System Build
woops! Well its all fixed now
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
this ram is really good and will save you a few bucks :)
