Hey fellas, this will probably be a bit long winded....sorry.
right no i am looking at upgrading my current i7-860 to newer and better things. first question is should i wait for Broadwell-E or just stick with Haswell-E. looks like Broadwell-E will be on the 2011-v3 socket, if that is the case and i do move forward with Broadwell-E should i wait for a newer Mobo or could i purchase a higher end one now and save more over time waiting for the chip to come out to put in it.
Budget is about 1500 USD for CPU,Mobo,Ram & GPU.
main task is gaming but i also dabble in virtualization, computing and usually have several home server applications running (ie Plex, Emit, Filezilla)
although my current rig has served me well for 7 years i am starting to feel it falling short with no USB3.0 or SATA3 ports and even if i was able to find a 2nd video card that matches my current one for a decent price ive heard the P55 chipset doesnt work well with Crossfire/SLI (due to PCI-E gen2 sockets and only 16 PCI-E lanes on the CPU i think)
Future Additions i hope to add will be a custom water cooling loop, a 2nd GPU, and a Freesync monitor at 1440p.
Current components that will be salvaged from current rig:
HX1000i
Obsidian 800D
Hard drives/SSD
1920x1200 24" & 1080p 24"
Features i would like to keep/add:
Dual gigabit ports on Mobo (would like to experiment with some type of link aggregation or use one of them directly for Virtual machines)
USB3 & SATA3
Wake on lan support (is that a thing yet on non-server stuff?)
any suggestions and help would be appreciated, also if anyone knows when we are expecting Broadwell-E to be released that would help me out too.
Thanks everyone, never thought i would be posting on a forum looking for build advice but i don't keep up with this stuff like i use to.
