My build now is sapphire 270x, cx600, 8gb ram, cooler cm tx3, mobo msi a78m-e35, 1tb hdd, athlon x4 ii 760k.
I live in Finland.
I am planning to buy these components gigabyte GA-970A-UD3P, fx-6300 and sapphire 280x. tell ne if there are aby bottlenecks and does 600w is enough for this upgrade.
The psu should be fine. The cpu cooler may need upgraded to a http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/. Keep in mind if your case has room for the larger cpu coolers. Everything else should run fine in combination with each other. If purchasing new consider the 380/390 for improvements and features.
Wait for 380.. Id suggest going with intel and a core i5.. ITS a fantastic bargain.. a little extra but you get a lot more performance.. the 6300 will be a bit of a bottleneck :)
u can find my spec in my profile. I want play on 1080 high to ultra 50-60 fps on bf4 witcher homeworld 2 and other popular games like new fallout, battlefront 3. Budget is around 600€ minus my old parts what i going to sell.
For under E600 I'm pretty sure you should be able to go i5 + GTX970/R9 390, but you'll have to hunt for deals. You've got a decent enough PSU, and I'm assuming you have some quantity of memory in your system already.
GPU is going to be more important than CPU for gaming.
