heres my current build
EVGA gtx 970 ACX 4gb 2.0
intel I5 4690k
Crucial MX100 128GB 2.5" Solid State Drive
G.Skill NS Series 8GB (2 x 4GB) DDR3-1333 Memory
WD Caviar blue 1TB harddrive
Asus Z97-A ATX LGA1150 Motherboard
Noctua NH-U14S 55.0 CFM CPU Cooler
Corsair CS series 750w power supply
fractal design r5 mid tower case
should i make any upgrades? the pc is being used for gaming
There should be no reason why you are upgrading, basically everything in your build is fairly new and should last a couple of years in terms of 1080P gaming.
I suppose another 8GB kit of RAM could be considered though if you are running into memory issues. If not, no reason too.
the ram is only 1333, but other than that everything else is solid
awesome just making sure I'm up to date don't want anything holding me back as far as 1080p gaming
if your looking for things to get i would consider a new monitor or keyboard.
This build is totaly fine, it will maxout any game at 1080p no problem at all.
I dont see any reason to upgrade something.
thanks guys I'm just going to get some better RAM and possible a dual monitor
Really good selection of parts too.
RAM speeds makes no difference in gaming once you have a dedicated graphics card(which you do)
