PC totally crashes randomly (Solved)
Title is fairly self explanatory. System has been built for about 2 weeks now but yesterday and today it has started randomly crashing. Today it was working for a good few hours until the first crash, turned it back on then about half an hour later I got one, then turned it back on again and it happened in a matter of minutes. Il give a list of some random stuff that may be relevant or possibly totally irrelevant.
I have a 1x network card running in a 16x slot at 4x
I have a backup saved on an external USB HDD
I was watching a film on the external HDD the last 2 times it crashed
System specs: AMD FX 4350 @4.2GHZ (stock)
AMD R9 270x Toxic (stock speeds)
1TB Seagate Barracuda 7200 RPM HDD
Gigabyte 970a-ds3
All these things may be totally irrelevant but I just wanted to get some info out there if it helps someone help me find an answer. As of writing this post I have only turned on the PC and come to this website and its been on for the last 10 mins.
make sure your cpu isnt overheating. also check if your PSU has enough wattage to run that toxic edition card. it may be happening becuase the power draw is too much for the psu, or you may have a deffective supply.
Its a 550W 80plus gold corsair RM 550, power shouldnt be an issue. System has been stable for the last half hour or so, I unplugged the external HDD that had the system backup on it, could that have somehow have been conflicting?
Just looking at your mobo it has a 4+1 analog power phase thats not heatsink'ed i am gessing your vrm's are geting hot with poor airflow has your video card pumps hot air in to your case.
However it could be a softwhere problem too what vershon of windows are you useing? have you installed anything new? how hot is your cpu geting? what psu do you have? did you install windows as a fresh instal?
Case is a fractal design define R4, 2 140mm fans intake, 1 140mm fan exhaust, no cables blocking air flow. Windows 7. The build was just a move from an old case but I swapped the GPU and changed PSU. Using corsar RM 550, dont have the means to check CPU temp at the moment but in the BIOS the temp was showing as around 20 degrees Celsius
20c is wrong (an less you live in a igloo) cpu's will idle just above room temp pick up something like speed fan/HWinfo64 ect and monitor your temps.
You said your system was running fine before you swapped out the GPU and PSU so probably safe to assume one of those is the source of your problem.  do you have the old GPU to see if that solves the problem.  As for seeing what your temps are you can download HWMonitor to see your CPU and GPU temps.
Downloaded HWinfo64 but cant actually see where it tells me how hot the CPU is, btw the system has been fine since I unplugged the external HDD for the last hour now
Never mind, CPU is idling at about room temperature
Its been running fine for the last 2 weeks in the way it is now, all seems to be okay for now but il keep you posted if it happens again, thanks for your guys help
Was a loose sata connector
