PC starts up then shuts down
Supp, I just built my first PC and when I start it all the fans and LEDs come on for a split second and then it shuts down. I've tried using 1 RAM stick and checked that all the cables are were they're supposed to be, and I have mounted the standoff screws. As well here are no loose screws in my PC.
SPECS:
Case: Fractal design R4
RAM: Corsair Vengeance 8GB CL9
GPU: GTX 780 direct CU II
CPU: i5 4670k
Mobo: MSI z87-G43
PSU: CX600M
CPU fan: intel stock fan
Help is much appreciated:)
Try without the gpu. That's all that I can think of.
Check that the front IO connections are correct - pwr, res, hdd, spkr etc.
Make sure that single stick of ram is in the correct slot. - refer to your motherboard manual for single channel details. Also try both sticks in case 1 is dead.
Disconnect any hdd's/ optical drives.
Remove the gpu completely and just use the onboard video output.
If things still fail and you can't get into the bios. Check to see that you havent damaged any of the socket pins whilst installing the cpu. - if there is damage then well. Yeah lets just hope there isnt.
Otherwise - it could very well be that the motherboard is faulty. In that case RMA it asap. Either that or the PSU is toast, only way to tell would be to do the above steps with another psu - spare or a friends etc.
thanks for the suggestions, I realized that I hadn't plugged in the jpwr 2 which I didnt know you had to plug in (noob move I know) But when I booted it the CPU fan didnt start so I turned it of in panic that it would overheat. So is it normal that the CPU doesnt start up in the booting process?
