PC start up problem
Hello,  I have built a PC this January and I had this problem since then. When i turn on my PC and it begans to load windows then it shows my account icon and enter password screen. After i type in a password and click enter. It loads a black screen but it does show me my cursor. When you see this you have to wait for a good 1-2 minutes before it starts to load my deskop.
I read online about this problem and they said the only way to solve this was to reinstall windows but I rather seek help from you guys. Any ideas on how to solve the black creen with cusor problems?
Thanks
I shall post on my profile the specs of my PC but I don't think that has anything to do with the problem.
What version of windows are you using?  And is it 32 or 64 bit?
WindowUltime 64 bit. should have included that. my apologizes.
Can't say I've ever heard of WindowUltime! At the risk of sounding like Google, did you mean Windows 7 Ultimate?
Sorry I am typing on my tablet. Yes, you are right i have Windows Ultimate.
When ever someone says " Im having trouble with my OS. Oh, forgot to mention im using windows 7 Ultimate." my mind always goes: "its pirated" I've never met anyone who has ever paid for windows 7 ult. Which makes me wonder about the integrity of the install and how it was activated. Is this legitimate install or am I correct in believing it was obtained by other means?
Short of reloading the system you could always try using msconfig and going into advanced boot options and telling the computer to use all its cores and maybe set it to use max ram (it will lower your available usable ram but speed up boot times a bit) also uncheck all the unnecessary programs that have themselves starting with windows under the startup section.
As a pirate I have to say I have pirated w7u before as well but I do have a legit copy as well now thanks to dreamspark. But I don't think anyone ever paid money out of his/her own pocket for w7u.
As far as your boot up problems, either a slow PC or a really bloated OS. Try removing some of the startup items as Nitro suggested if it doesn't help I think I'd try a reinstall.
wenn you have so much problems wenn loading your desktop there might some problem with spyware malware of maybe a virus. or some driver issue that doesnt load correct, or a startup proces that causes problems.
p.s there is nothing wrong with a pirated windows version, i have allmost all versions of windows, its just  you have to know to wich kind of pirated versions, you have to look.
not those versions where they put all kinds of extra´s into it. cause those  are crap.
just reinstall windows
dudes... I am running win 7 ultimate - legit version
Just saying... dont expect a cookie or a medal :P
