Please help!!! Every time i run Furmark or graphically intensive games my computer automatically shuts down (like if i were to unplug it from the outlet w/o any warnings or errors)...
Yes I have done my research here's what i found! This guy is having pretty much the same problem as I do... As Soon As I Run Demanding Programs Comp Fails! (http://forums.majorgeeks.com/showthread.php?t=255295)
From what I've seen and read It seems that it is a PSU problem/issue or Heat. I'm not sure thus I'm here.
Here's My Set Up:
MB - Gigabyte 970A-D3P
CPU- Amd 8320 (3.5 - 4.0 ghz) (using Stock Cooler)
MEM- PNY 1333 4x2 GB
GPU- Asus R9 270 2gb (non X) (975/1400)
PSU- Corsair CX600m
Storage- Samsung 840 EVO (250 gb)
Case- Antec Black GX700
---- Note... Every Part/Component is brand new and not even a year old!
Yes now... I've also done my own tests. Ive clean the filters, grills, fans, case, gpu, cpu cooler, everything...
(Note---- There's 10-15 min rest in between the tests with the fans at 100% to cool down components)
HERE's THe Tests: -With Furmark-
(Note---- I did the test INSIDE the case and OUTSIDE!)(Yes I unplugged everything and tested it outside the case on the MB box)
- Installed inside the case:(2 120mm intake fans and 2 140 exhaust fans) Decent airflow
With Cpu and Gpu speed/clock at Stock... -Fail/Shutsdown. (*after 10-15 sec. Sometimes even as soon as furmark is ran).
With Gpu oc (with msi afterburner) to +10 power, 1025,1425... -Fail/Shutsdown. (Same as before. Above*).
- Outside the case: (With everything outside including PSU)
With Cpu and Gpu speed/clock at Stock...-Success/Did not shutdown (Ran for 3 hours no shutdowns and no problems).
With Gpu oc (with msi afterburner) to +10 power, 1025,1425... -Again Success/Did not Shutdown (Ran for 2 hours no problems).
I have no Problems with my cpu and the stock cooler that came with it. I Ran Prime95 all day with no problems. Only With Graphically Intensive Games (BF3, BF4, Modded Skyrim) and Furmark.
So with that I will consider any help or suggestion I get. Because I'm really confuse. HEAT or POWER SUPPLY? Thanks in advance.
.........uPDATING fIRST tHREAD (Sorry about not mentioning this Guys!!!)........ [7/6/14 20:01]
When I first built my system I originally had used an amd 4300 and I remember I didn't really have any problems/shutdowns... (everything else is the same. component wise psu, mb, gpu ! again sorry about not mentioning this!)
Does this information help?
