PC randomly shuts off and turns back on no post
Okay so first off, I've noticed it for a while now, last time I had this issue the GPU was faulty and got RMA'd, but the issue is happening now, except last time it wouldn't post at all ever... Now it posts if I restart it. basically the computer shuts down instantly, almost as if the power was cut, then it turns back on and refuses to post until I hard shut down and turn it back on. Am i running into a power issue? or?
The parts I have are:
ASUS GTX760-DC2OC-2GD5 GeForce GTX 760 2GB 256-Bit GDDR5 PCI Express 3.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121775
ASRock Z77 Extreme3 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157330
CORSAIR CXM series CX600M 600W ATX12V v2.3 SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050
Intel Core i5-3350P Ivy Bridge 3.1GHz (3.3GHz Turbo) LGA 1155 69W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116782
G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
I also have a 1TB hard drive that I picked up.
Thank you for your consideration and help.
check the voltage on your psu 24 pin. are you using a power conditioner/ups? It may be a bad chip or mobo but start with the psu first. Also double check your case and motherboard grounds and your wall power.
... unseat and reseat your graphics card and RAM. Usually it will beep at you if they're not in all the way but not always. 9/10 this is the problem with bootcycles like this or if it's just running the fans and not posting.
