I built a PC about 6 months ago, and every so often it will freeze up. I will be browsing the web or looking through a folder, and it will just freeze. Typically it takes about 10 seconds to come back to normal, and all the stuff I clicked on during the freeze will suddenly open up. I think it may be my HDD, but I'm not sure and was wondering if anyone has had a similar experience. Everything else works fine, and it only seems to happen when I'm on the desktop. It has never happened during a game, for some odd reason.
I don't have any viruses or resource hungry programs running in the background. The only thing I have set up to run on start-up is AVG Free and Nvidia GeForce Experience
You can check windows event viewer, see if anything pops up there, could be a couple of things,
Check your HDD sleep timer under power options, set your CPU min to 50%, if its on something like 5-10 currently.
Now, windows 8 is made up, so that all programs go into frozen status, when you are not using them, so it might be something popping up from time to time, and forcing everything else to go idle. So check the event manager, most likely you will find the culprit there
