PC part building help!
Hey guys I am a new member to the "TekSyndicate" and I am planning to build a PC I have looked around and come up basically blank so would appreciate some help from you guys as I reckon you all have far more experience than I do.  Without further ado here is all the stuff (I think) you'll need
  •  Budget: my budget is £200 - £300
  • Where do you live (what country):  I live in Britain and use the pound
  •   -Is there a retailer you prefer: No
  • Do you need or already have peripherals? Yes (mouse, keyboard, monitor)
  • What will you be using your future computer for? I would be using my PC to animate (2d and 3d), 3D rendering and design, video editing, and of course,  gaming.
  • Do you overclock or want to get into overclocking? I have no idea how but if it improves performance, I would be willing to learn
  • Do you plan on going for custom watercooling now, or in the future? Not really
  • OS. Do you need a new one? No, I have Windows 7 and I like it
If you Game-
  • What kind of settings do you like or what FPS do you want to play at? Ideally as high as I can but not much below 30FPS
  • What resolution will you be playing at? //or would like to play at. Ideally 1080p but that's  ideally, I would be happy to go for 720p
  • What kind of games do you like to play? Whatever looks good (gmod, TF2 and yes, my guilty pleasure, Minecraft)
  • What specific game will you be playing? probably any of the above
If you Render or Edit things-
  • What application do you use to render? Autodesk Inventor and Maya
  • Do you render movies or just photoshop pictures? just photoshop but would like to get into rendering films
Other Notes:
This is going to be my first build but I am a quick learner and it looks simple enough ;)
Thanks for the help, much appreciated,
Xvantok
You might want a higher budget or look for used parts online because for animation you are looking at spending a lot on the cpu alone.
http://uk.pcpartpicker.com/p/vyVhvK
That would get by ... and is in budget
Ideally you need a larger budget as you will find out down the road as your projects get larger.
but this is a start
http://uk.pcpartpicker.com/p/gxxn99
Still a bit over budget :|
It is a bit but if you think having a 2gb video card would dramatically improve performance over a 1gb then I might be able to find some cash to splash on one
The R7 265 is a much better performer than the R7 260.  I would rather not go lower.  Here, the R7 260X(which is a step above the R7 260) has a pretty significant difference in many games.  Since the R7 260 has even less stream processors, expect a bit lower performance.
http://www.anandtech.com/bench/product/1044?vs=1127
Anyone else got anything they can add? I am thinking about going for the option below but would like a second opinion on it just so I don't go off and waste £400
pc part picks
