Well guys, I'm tird of consoles. So I sold my ps3, and with some extra hard work I was able to muster up about $500. So, this is my budget. I'd like to share what I'd like to build, and ANY help would be appreciated... Any.
Well, it looks pretty good, I'm not sure about the Biostar motherboard, I've never used a biostar but I would still like to recommend an ASUS or Gigabyte motherboard instead.
Also, you may want to consider simply buying a Radeon 6670 when you have a bit of extra money in the short term to boost the graphical performance of the rig. I know my brothers A8 with a Sapphire 6670 (DDR5) is pretty dang powerful for the ~$550 I put into it. Would give your rig a boost at least until you can upgrade to a more powerful build.
Also note that the $511 price on your build is only if you get all your rebates....which I wouldn't count on.
