I have built a Beast PC with a high end AMD GPU, so it has Eyefinity (3 Screen Setup). And I was wondering whether it would be better if I got 2 x 19.5" (1600x900 5ms) monitors AND a big 24" monitor (1920x1080 1ms) --- OR --- 3 x 22" (1920x1080 5ms).
I my opinion the 3 x 22" would look better as a setup and would work better with the AMD Eyefinity. However, I do like the idea of having a big 24" monitor to play on and then 2 x 19.5" monitors at the side - although this wouldn't be as compatible with the AMD Eyefinity.
They all cost the same price as a set and they take up roughly the same space.
If you would be able to tell me which you would go for and why, I would very much appreciate it.
just go 1080p. I don't think that 3 monitor gamimg will satisfy over time because you have to move your head all the time. I like having a second monitor for watching videos while gaming. Or just get a 34" 21:9 monitor
£300? How about 3x21,5" freesync monitors? AOC G2260VWQ6... £95 each, 1080p 50-75Hz freesync range, 1ms response, low blue light for less eye strain... Or you can go for standart 1080p screens 60hz... But I think similarly sized screens will be better...
They would... You may also be able to probably get 24" 1080p... But you have high end AMD GPU, as you said. This is why I offered you the freesinc option, available for your budget. AOC also have 24" freesync for 124£... My main idea was the freesinc option. You can easily go for non freesync one...
I would recommend getting 3 screens that are from the same manufacturer and with small bezels (if possible). I run 3 x Dell U2414H screens and for gaming they're great! (running on a GTX 780Ti)
Just a thought ! ever considered a 39/40; just great for immersion ! I personally tried eyefinity with 3 40 s and ended up trying 2 and finally , 1 monitor was the best ! and much less of a hassle for colour balancing, no bezel, and mainly no twisting of my head ! Just a Thought ! happily I am the second one to have that great idea ! :-)
