Pc making clicky sound?
MY pc is making clicky sounds is not that loud tho is this bad? im using phanteks 14pe
you canbarely notice it but if u go near the pc it makes a low noise clicky sound could it be the fans?
if its only sometimes its probably the harddrives if its all the time if could be a fan
ok thanks when should i start to worry?
If it's the harddrives, I'm pretty sure you should worry now. I'm no expert, but my brother's external HDD clicked before it died two days later. So make sure it's not your HDD.
That's not entirely true, old HDDs always made clicking and clunking sounds. They still do in modern HDDs but its far less noticable because the parts are much smaller. Grinding noises is what I would be more worried about when it comes to HDDs as it means the platter motor's bearing is about to lock up.
