Pc help
Hello,
I am going to order a new pc but i just wanted to check if all the hardware work is compatible with each other.
Some parts are taken from Best low priced gaming pc 2013.
  • CPU: AMD Phenom II X4 955 Black 3.2GHz Quad-Core Processor
  • Motherboard: ASRock 960GM/U3S3 FX Micro ATX  AM3+ Motherboard
  • Memory: Mushkin Redline 8GB (2 x 4GB) DDR3-1866 Memory
  • Storage: Seagate Barracuda 1.5TB 3.5" 7200RPM Internal Hard Drive
Video
  1. MSI N660 TF 2GD5/OC 6008 MHz NVIDIA Active
  • Case: /
  • Power Supply: Do i need to adapt it to my grapics card?
And i wanted to see if you guys think its worth it
you probably won't need to use an adapter for you graphics card. however, I suggest taking a look at AMD gpu options as well, and save up for a future CPU upgrade to a vishera 2.0 cpu that will come out in june.
Wich ones? ;D
http://pcpartpicker.com/p/Ftoa
A tad more expensive,but it's alot better than what you have currently.
