Pc help appretiated
how can i find out what type and wattage of power supply i need for my computer?
i have
Asus Black 12X BD-ROM
WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200
AMD FX-6300 6-Core Processor Black Edition
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR
Gigabyte AM3+ AMD DDR3 1333 760G HDMI USB 3.0 Micro ATX Motherboard
EVGA GeForce GTX 760 SC 4GB DisplayPort HDMI DVI-I/DVI-D Graphics Card with ACX Cooler 04G-P4-2768-KR
for cases maybe one of this tree
Fractal Design Core 1000 FD-CA-CORE-1000-USB3-BL Black Steel MicroATX Mid Tower Computer Case
Rosewill LINE GLOW ATX Mid Tower Computer Case,Dual USB 3.0,come with Four Fans,Support up to 7 Fans
Item #: N82E16811147170
rosewill line glow mid tower computer case usb 3.0
Smallest I personally would go is a 600w. That should still give you some headroom, if you're worried about it just grab a nice 750w and never think about it again.
750w got it anything else i should know about the power supplys?
The computer would even run safe on a 500w, I just personally would rather  have more than less when it comes for a Power Supply. Make sure its a 80+ certified power supply and single 12v rail.
oh ok i get it better safe than sorry i guess btw what does the 80+ and 12v rail mean?
This Image kinda explains the single 12v rail
and 80+ certified means that under full load it is still atleast 80% efficient at its power usage/output
here's a really good deal on a 80+ Gold certified PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153170
ill keep that in mind thanks man for the help been really help full
