Pc from scratch
hey im 13 years old and want to build my first computer. i have around £550 and want the pc for gaming and schoolwork. i have some specs but i think the go abit over my budget. if you could see if u have some specs for my build that would be great.
Oh and i need everything from the os to the monitor and i want to build the system myself as i know how to build a pc
Specs:
Case: No preferance as long as it looks niceCPU: Intel Core i3-3220 Dual core (3.30Hz, 3MB Cache)+HD GraphicSMOTHERBOARD: ASUS P8H61-MX USB3/SI: uATX, USB 3.0, SATA 3.0Gb/sRAM: 4GB samsung dual-ddr3 1333MHz (1x4GB)GRAPHICS CARD: 1GB NVIDIA GEFORCE 210-DVI,HDMI,VGAHARD DRIVE: 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CacheDVD/BLU-RAY DRIV: 10x BLU-RAY ROM DRIVE, 16xDVD+R/+RWMEMORY CARD READER: INTERNAl 52 IN 1 CARD READER (XD,MS,CF,SD,ETC)+1xUSB2.0 PORTPOWER SUPPLY: 450W QUIET 80 PLUS Dual Rail PSU=12Omm CASE FANPROCESSOR COOLING: SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLERSOUND CARD: ONBOARD 8 CHANNEL(7.1)HIGH DEF AUDIO NETWORK FACILITIES: 10/100/1000 GIGABIT LAN PORT(STANDARD ON ALL PCs)USB OPTIONS: 4XUSB 2.0 PORTS @ BACK PANEL(MIN 2 FRONT PORTS)AS STANDARD OPERATING SYSTEM: GENUINE WINDOWS 8 STANDARD EDITION 64 BIT-INC DVD & LICENCEOFFICE SOFTWARE:MICROSOFT OFFICE HOME & STUDENT 2010ANTI-VIRUS: NORTON ANTI-VIRUS 2013 1 YEAR 1 PCMONITER: ANY HD MONITER
Thanks
           that kid :)
i3 is not for budget gaming, see our new $350 build. and a blu-ray drive is unneeded unless it's a home theater pc
your gonna want 8 gigs of ram
pcpartpicker.com
thanks for the quick reply and i have watched the video proior to posting this post but i didnt know if i should change the procesor or not
thanks for the advice
that processor is a little better than an i3 as a cpu, but it has a real gaphics processor in it
and use that websit, it will get you your parts the cheapest, and check for compatibility
also what cpu cooler would you suggest for the amd a10 cpu
hyper 212 evo
cheers
this is what i got so far on that website
 and all that only costs me £384 (because im british
Going to go and whip up some other things that i need
just save the build, and stick with win7, win8 sucks. good choice on the monitor. WD drives are more reliable than seagate. good choice on the psu as well.
and get like ddr3 2133 ram, it makes a huge difference with the apu's.
ok cheers
I just have 2 questions is there any point buying a second moniter
and do you know of any good keyboards and mouses i cant find any that are good or that look nice
also which version of win7 home p or pro
good mouse: deathadder
keyboard: since ur on a budger, get a random $20 keyboard that appeals to you
and don't get a 2nd monitor right away if your on a budget.... you can add one later
home premium, pro is only needed if you got more than 16g of ram
ok and big thanks for the quick responses and advice much appreciated
this is what i got with your advice
CPUAMD A10-5800K 3.8GHz Quad-Core$119.99
CPU CoolerCooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing$28.98
MotherboardASRock FM2A75M-DGS Micro ATX FM2$44.99
MemoryG.Skill Ares Series 8GB (2 x 4GB) DDR3-2133$60.99
StorageWestern Digital Caviar Blue 1TB 3.5" 7200RPM$69.99
CaseMSI IN-623 (Black) ATX Mid Tower$39.99
Power SupplyCorsair 500W ATX12V$41.98Optical DriveAsus DRW-24B1ST/BLK/B/AS DVD/CD Writer$24.98
MonitorAsus VH236H 23.0"$139.99
Operating SystemMicrosoft Windows 7 Home Premium SP1 (64-bit)$91.99
KeyboardRazer Arctosa$40.24
MouseRazer DeathAdder Wired Laser$46.00
Total:  $750.11
Total £471.16 (I think)
One more quick question do i need a sound card as the video didnt mention one
oh and im buying microsoft office home and student do you know where sells it for the cheapest as i need it to do schoolwork
To build a PC from scratch, you must first invent the universe.
And that was useful to me because ?
hmm...I did that once. Yeah...big bang...that was all me.
To unbuild my computer, I will induce the big crunch.
