Pc freezing!
My Pc freezes every so often while using the internet or little load. While gaming, my PC has not frozen at all and I need help figuring out my problem. My temps are good, CPU idle is 23C and full load is 61C, Gpu is 34C idle and 63C on full load. I have replaced my RAM, and checked all my storage drives, no errors with my SSD or HDD. So my only things left are my CPU, Motherboard and the PSU.
Specs:
Cpu: Amd 8350 Vishera
MB: Gigabyte 990 fx ud3
Ram: Corsair vengeance 1600 mhz 4gbx 2( other Ram is Gskillz Ares 1866mhz 4gb x 2)
PSU: Seasonic 620 80 plus bronze
GPU: Evga GTX 670 FTW
OS: Win7 64 bit
It's the nvidia drivers mate. Check out https://forums.geforce.com/default/topic/546165/geforce-drivers/geforce-r320-xx-display-driver-stability-feedback-thread/
I've just been troubleshooting my gf's PC and finally found the cause (she's been complaining for a few days haha) are those drivers. Just updated to the beta driver 320.49 and it seems to of fixed it.
I've reverted back to 314 for a bit and I was still freezing. So that doesn't seem to be the problem.
Temps?
Everything plugged in correctly?
I have my temps above....
Yes, everything is connected correctly.
