A while ago I decided to install Linux (Manjaro to be more specific) on my old PC (i5 2500k) and wanted to use it for various tasks.
However, when I suspend the PC a wake it up from it, it hangs immediately afterwards. Thus far, I’ve tried to take a look at the journalctl logs, but I haven’t discovered anything interesting. The very last log looks like this:
Okt 20 13:28:14 cptOldschool systemd[1]: Starting TLP suspend/resume...
Okt 20 13:28:14 cptOldschool systemd[1]: Started TLP suspend/resume.
Okt 20 13:28:14 cptOldschool audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 20 13:28:14 cptOldschool systemd[1]: Reached target Sleep.
Okt 20 13:28:14 cptOldschool systemd[1]: Starting Suspend...
Okt 20 13:28:14 cptOldschool kernel: audit: type=1130 audit(1540034894.785:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Reboot --
Okt 20 13:29:48 cptOldschool kernel: microcode: microcode updated early to revision 0x2e, date = 2018-04-10
Okt 20 13:29:48 cptOldschool kernel: Linux version 4.18.15-1-MANJARO (builduser@development) (gcc version 8.2.1 20180831 (GCC)) #1 SMP PREEMPT Thu Oct 18 17:35:17 UTC 2018
Okt 20 13:29:48 cptOldschool kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-4.18-x86_64 root=UUID=f1a0bb23-e335-4cda-83c2-71ee4efd45f4 rw rootflags=subvol=@ quiet clocksource=hpet
so nothing of note here. On a previous suspend the logs where more conclusive. (Probably because it let it running for 30min afterwards):
Okt 19 16:31:28.311288 cptOldschool kernel: PM: suspend entry (deep)
Okt 19 17:55:57.306869 cptOldschool kernel: PM: Syncing filesystems ... done.
Okt 19 17:55:57.307671 cptOldschool kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Okt 19 17:55:57.307755 cptOldschool kernel: OOM killer disabled.
Okt 19 17:55:57.307826 cptOldschool kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Okt 19 17:55:57.307895 cptOldschool kernel: Suspending console(s) (use no_console_suspend to debug)
Okt 19 17:55:57.307971 cptOldschool kernel: wlp3s0: deauthenticating from d8:b6:b7:c9:c1:39 by local choice (Reason: 3=DEAUTH_LEAVING)
Okt 19 17:55:57.308041 cptOldschool kernel: sd 6:0:0:0: [sdb] Synchronizing SCSI cache
Okt 19 17:55:57.308441 cptOldschool kernel: sd 3:0:0:0: [sda] Synchronizing SCSI cache
Okt 19 17:55:57.308760 cptOldschool kernel: serial 00:04: disabled
Okt 19 17:55:57.309033 cptOldschool kernel: sd 3:0:0:0: [sda] Stopping disk
Okt 19 17:55:57.309333 cptOldschool kernel: ACPI: Preparing to enter system sleep state S3
Okt 19 17:55:57.309406 cptOldschool kernel: PM: Saving platform NVS memory
Okt 19 17:55:57.309477 cptOldschool kernel: Disabling non-boot CPUs ...
Okt 19 17:55:57.309550 cptOldschool kernel: smpboot: CPU 1 is now offline
Okt 19 17:55:57.309622 cptOldschool kernel: smpboot: CPU 2 is now offline
Okt 19 17:55:57.309694 cptOldschool kernel: smpboot: CPU 3 is now offline
Okt 19 17:55:57.309764 cptOldschool kernel: ACPI: Low-level resume complete
Okt 19 17:55:57.309835 cptOldschool kernel: PM: Restoring platform NVS memory
Okt 19 17:55:57.309905 cptOldschool kernel: Enabling non-boot CPUs ...
Okt 19 17:55:57.309978 cptOldschool kernel: x86: Booting SMP configuration:
Okt 19 17:55:57.310053 cptOldschool kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Okt 19 17:55:57.310126 cptOldschool kernel: TSC synchronization [CPU#0 -> CPU#1]:
Okt 19 17:55:57.310198 cptOldschool kernel: Measured 2648962091 cycles TSC warp between CPUs, turning off TSC clock.
Okt 19 17:55:57.310271 cptOldschool kernel: tsc: Marking TSC unstable due to check_tsc_sync_source failed
Okt 19 17:55:57.310341 cptOldschool kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
Okt 19 17:55:57.310414 cptOldschool kernel: sched_clock: Marking unstable (25544676641764, -3717552)<-(25544674455380, -145813)
Okt 19 17:55:57.310488 cptOldschool kernel: cache: parent cpu1 should not be sleeping
Okt 19 17:55:57.310560 cptOldschool kernel: CPU1 is up
Okt 19 17:55:57.310629 cptOldschool kernel: clocksource: Switched to clocksource hpet
Okt 19 17:55:57.310704 cptOldschool kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Okt 19 17:55:57.310791 cptOldschool kernel: cache: parent cpu2 should not be sleeping
Okt 19 17:55:57.310872 cptOldschool kernel: CPU2 is up
Okt 19 17:55:57.310942 cptOldschool kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Okt 19 17:55:57.311007 cptOldschool kernel: cache: parent cpu3 should not be sleeping
Okt 19 17:55:57.311077 cptOldschool kernel: CPU3 is up
Okt 19 17:55:57.311141 cptOldschool kernel: ACPI: Waking up from system sleep state S3
Okt 19 17:55:57.311211 cptOldschool kernel: serial 00:04: activated
Okt 19 17:55:57.311461 cptOldschool kernel: usb usb2: root hub lost power or was reset
Okt 19 17:55:57.311797 cptOldschool kernel: usb usb3: root hub lost power or was reset
Okt 19 17:55:57.312111 cptOldschool kernel: sd 3:0:0:0: [sda] Starting disk
Okt 19 17:55:57.312410 cptOldschool kernel: usb 3-2: reset SuperSpeed USB device number 2 using xhci_hcd
Okt 19 17:55:57.312740 cptOldschool kernel: OOM killer enabled.
Okt 19 17:55:57.324387 cptOldschool kernel: Restarting tasks ... done.
Okt 19 17:55:57.324464 cptOldschool kernel: PM: suspend exit
Okt 19 17:55:57.387469 cptOldschool kernel: ata6: SATA link down (SStatus 0 SControl 300)
Okt 19 17:55:57.397456 cptOldschool kernel: ata5: SATA link down (SStatus 0 SControl 300)
Okt 19 17:55:57.397525 cptOldschool kernel: ata2: SATA link down (SStatus 0 SControl 300)
Okt 19 17:55:57.400790 cptOldschool kernel: ata1: SATA link down (SStatus 0 SControl 300)
Okt 19 17:55:57.400857 cptOldschool kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Okt 19 17:55:57.407456 cptOldschool kernel: ata3.00: configured for UDMA/100
Okt 19 17:55:57.845927 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
Okt 19 17:55:57.846015 cptOldschool kernel: enp4s0: 0xffffaa0b81a39000, 00:25:22:e8:51:9f, IRQ 30
Okt 19 17:55:57.917463 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
Okt 19 17:55:57.920804 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Okt 19 17:55:57.924144 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Okt 19 17:55:57.934132 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Okt 19 17:55:58.000910 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Okt 19 17:55:58.894128 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Okt 19 17:55:59.440818 cptOldschool kernel: ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Okt 19 17:55:59.474175 cptOldschool kernel: ata4.00: configured for UDMA/133
Okt 19 17:55:59.824145 cptOldschool kernel: wlp3s0: authenticate with d8:b6:b7:c9:c1:39
Okt 19 17:55:59.830920 cptOldschool kernel: wlp3s0: send auth to d8:b6:b7:c9:c1:39 (try 1/3)
Okt 19 17:55:59.857479 cptOldschool kernel: wlp3s0: authenticated
Okt 19 17:55:59.864150 cptOldschool kernel: wlp3s0: associate with d8:b6:b7:c9:c1:39 (try 1/3)
Okt 19 17:55:59.864406 cptOldschool kernel: wlp3s0: RX AssocResp from d8:b6:b7:c9:c1:39 (capab=0x411 status=0 aid=10)
Okt 19 17:55:59.864531 cptOldschool kernel: wlp3s0: associated
Okt 19 17:55:59.894193 cptOldschool kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
You might notice it complaining about TSC in this log, but I already set my timesource to hpet, because I’ve read that this could have been related…
I’d be grateful for any help
- Since this error is easy to produce, I can provide additional logs if/when they are needed…
