PC for my girlfriend
My girlfriend wants a PC for playing games and watching movies and such.  She's no hardcore gamer, but she likes some fairly demanding games.  How is this?
http://pcpartpicker.com/p/NL6f
Budget?
Well, that mobo will not fit in the case, swap it out for a standard ATX mid tower like a Xigmatek asgard pro. Use the money you save to buy a better motherboard like the gigabyte GA-990-fxa-ud3. Otherwise, looks good.
$650 is a nice area.
It's a LAN build.  Sorry I didn't mention that.
You will need a mini ITX mobo then.
Yeah I actually didn't even notice it wasn't mini ITX.
How about this mobo then?
http://www.newegg.com/Product/Product.aspx?Item=13-157-323&Tpk=N82E16813157323
Hey but sometimes mITX can be expensive right?
nope, bitfenix prodegy is m-itx, it fits m-itx and nothing else
i'm not sure if they make any m-itx am3+ boards
I meant the board actually.
oh, so you're fine with changing to a bigger case
No I'm not lol.
I've never seen anyone who bought a Seagate HDD and didn't have it die after a few years.  Spend $5 more for a 1tb Western Digital.
THANK YOU!!!
I keep telling everyone that, and no one believes me so I finally jumped on the seagate bandwagen!
At the very least even if it's wrong to say Seagate is unreliable it is for certain less reliable then Western Digital and $5 is a small price to pay if it means the difference between keeping everything on your computer and loosing it... (Though backing up is still a good idea)
you misunderstood my first post, if you're going with that case (the prodegy) you need an m-itx board, the board you posted was m-atx
and i don't believe they make any m-itx am3+ boards (or am3, but idk), you may need to go intel
I understand what you mean now.  In which case, I found this case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154094
yeah, that should hold that second board you posted
i don't know a ton about motherboards, so i dont know if that's neccasarily good board (literally no idea whatsoever) but it'l fit and work
http://pcpartpicker.com/p/PGRu
