Hello everybody, I just got done putting together a list of parts for a home office pc for my dad. He wants the pc to be VERY quite, to be able to run Train Simulator 2013 (he loves trains), and be energy efficient. Will these parts do the job? btw he wants the pc to be no more than $600 (I'm willing to cover the extra $24)
If you really must have that case then here is my recommendation, pulls less than 75w with all components at full load, probably less than that but 75w is a good estament
that ram runs at 1.25v, HD4000 can play minecraft decently and is better than a 610, a GTX650 is overkill for MTS 2013 and will just draw more power and more noise
enter in the promo code newcustomer to get 10 bucks off in addition to the 5 from the PSU promo, set the fans to a low speed, the gaia could almost passively cool that i3
180GB should be enough for your dad if not go with that mechanical drive but a SSD uses 1w opposed to the 20w or more a mecanical one uses and its faster
I would get a cheaper but still appealling case and get a larger SSD just incase
if train simulator is all hes gonna play you can save a bit and get a lower end gfx card. maybe even a fanless solution. although i would still recomend you add a fluid dynamic bearing fan (silent)
Be-Quiet do some excelent silent fans. i have 1 on my cpu and you cant hear it at all even when its going top tit.
with these you wouldnt be able to tell that the pc is actualy working there so quiet.
also spend an extra couple of bux and get a seasonic unit there quieter than the corsair 1s.
I also agree with gigabusterEXE with getting an SSD if you can spare it. Just maybe for his OS and some games/application to help them run better. It doesn' have to be bigger than the 64GB flavor, but ofcourse the bigger size helps.
