Hi! I have been REALLY into PC's and stuff, a couple of years ago, but the tides has turned and I'm now all about music. I need to build a PC for Music production (Running a Surface pro with Ableton Live 9 Suite, and think an upgrade comes to right). If you've got any experience with this, hit me!
The reason i don't want to give it a go, is that i don't have ANY experience with production oriented PC's, more like gaming! But that's not what I need, although if a computer that is focused towards music production can play games, and do AfterEffetcs, then I'll gladly take that!
Hook up with me, if you have some advice on what to buy. (I'm not biased in any way, towards any brand, since i've owned most, and never has anything failed me). The other thing, is that i don't have a despicable amount of money, so please, not too expensive.
Cheers, Frede!
P.S. EVERYTHING is fucking expensive in the DK and therefore, things that seem cheap in the US aren't necessarily cheap where i live. I use DKK (Danish Crowns) and 1 USD equates to roughly 5,5 DKK, Pounds-wise, 1 GBP = 9 DKK
P.P.S Here are a feww of the sites that i consider buying on!
http://www.computersalg.dk/g/193
https://www.komplett.dk/k/kd.aspx?bn=10000
http://cdon.dk/hjemme-elektronik/computer_komponenter/
And hereby a little glossary, so that you can brag on danish:
Bundkort = Mobo
Grafikkort = GPU
Strømforsyning = PSU
Ask if there's anyting else, otherwise, Google is your friend!
Thanks!
