Pc for dayz and bf4
Ok so im biulding a computer for my bday and i want it to be able  to play dayz and bf4 at ultra settings  35fps or more at a 600-750$ price range i only have the moniter keybord and mouse
One question, Do you have a  optical drive, monitor, keyboard, mouse, etc.. and do you already have hard drives for storage
i dont have eny parts or enything all i have is the moniter keybord and mouse
Here is a build for $675:
http://pcpartpicker.com/p/1LjGX
for the upper end of your budget replace the fx-6300 with fx-8350
http://pcpartpicker.com/p/1LjKG
Should handle BF3 and DayZ no prob.
I know this is over your budget but because you have abousloutly nothing you need things like a hard drive and an operating system and a power-supply... it has to be if you want to play on ultra at least in my opinion. http://pcpartpicker.com/p/1LjNG from these parts i'd probably pick some cheaper parts to fit your budget and then upgrade in the next year, or save up some more money. Again this is my opinion, you can do whatever you want (:
Here's the best you can get for the money!
CPU $150 amd a10 6800k http://www.newegg.com/Product/Product.aspx?Item=N82E16819113331
Hard Drive $120 Hybrid 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822178340&ignorebbr=1
Ram $75 8GB 1866mhz http://www.newegg.com/Product/Product.aspx?Item=N82E16820178412
Mobo $60 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130662
Psu $65 500w http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
Gpu $240 amd 7950 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127734
Disk Drive $20 http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Total Cost :$730
I did not include the cost of windows 7, or a case because that's more of a personal choice.
ok this should work i also forgot to say i have window 7 proffesinal already but if someone has eny better ideas please tell
This is what I've seen as far as cpu performance on BF4, so it appears an i7 or AMD 8 core is the way to go:
Oh okay so it does fit in your budget, Well the best of luck to you whatever you end up doing!
http://secure.newegg.com/Shopping/ShoppingCart.aspx?Submit=view                          would this pc biuld work really good?
link doesn't work, use http://pcpartpicker.com/
http://pcpartpicker.com/parts/partlist/
This is my biuld will it run bf4 and dayz ultra settings at around 30fps
You need to use the permalink in the top left corner.
This would be the best you can get for $750
http://pcpartpicker.com/p/1Lkly
If you put a build with a 7950 in you dont need a fm2 socket cpu. Instead put a am3+ socket cpu in.
isnt the amdfx8350 better??
Yes but in a budget of 750 you probably won't be able to squeeze it in. I'll try though.
http://pcpartpicker.com/p/1KORg
ok i think this is the right link will this biuld be good??
http://pcpartpicker.com/p/1Lkzs
This is about the best performance you can get for around $750, it should give you around 30fps on ultra, (at least the cpu is good enough), we won't now the final performance though until the BF4 version with the Mantel API is released.
You won't really see much benefit from that fast of ram, I would stick with 1600mhz ram and get a better motherboard, that can handle the FX-8350 better.
