So,
A friend of mine - Who i didn't think liked computers - "asked" me if for a rig to play Titan Fall at medium-high settings. He didn't say a price so i thought $700 to $800 ended up with $800. Resolution I think he will play 1080p but i am not sure.This is what I thought would be good: http://pcpartpicker.com/p/2BQrp <- this is the real link
cpu good with the gpu wasn't sure.
I wanted to put a R9 280 but only had a the X model; to expensive .
-Your friend
Chris
Titanfalls system requirements have not been published yet but the game is being made using the Source engine so should not be very demanding and can be easily played on the new consoles so a decent PC will have no trouble.
Honestly, the parts you've picked are pretty overkill for Titanfall on Medium, this will probably max out the game at +60fps. The 4770 is not necessary, save the money and get an i5 4670 (non K). The hyperthreading on the 4770 won't do any good in gaming. The motherboard is too high end for a non K processor, if you stick with intel, consider the Asus Z87M-plus. The GTX 770 is a great card and is pretty much neck and neck with the R9 280x but, again, I think this might be overkill and you could probably run the game fine on a GTX 760. One more thing, the HDD is the black version which normally is used by professionals as it's incredibly reliable drive type, if you just want storage spacve to put games on, get a caviar blue or green drive and save some more money there.
http://pcpartpicker.com/p/2BQrp <- this is the real link Sorry for the mix up
All looks good. I'm not sure how good the motherboard is at overclocking but you can probably get 4.0Ghz out of the CPU with the Hyper 212 if you wanted to. I would probably add the Hyper 212 anyway, even without an overclock as they're only $20-$30. Also i'm not sure how easy it will be to get a 7870, perhaps a 270x would be more readily available and about the same price.
Go this way: http://pcpartpicker.com/p/2BRrA the R9 270x is a slightly faster 7870 and is a little cheaper. Also you have a lot better motherboard with the ASUS 990fx evo.
Do you already have a case for this? Take a look at the Fractal Design Core 1000.
The G46 motherboard he selected only has a 4+1 power delivery system so your pretty much guaranteed to fry it with any overclock.
I'm liking this build.
FX-8350 upgradeability, Crossfire-able if you don't overclock.
I would prefer a higher quality 650w psu if your friend plans on adding another 270x.
Ok so i forgot the case on my build so yea anyway here a final build -> http://pcpartpicker.com/p/2C0jI
here he can upgrade to the FX-8350 or get another gpu and more ram
2 things, don't get 1 stick of ram, get two 4gb sticks. It will be slightly higher performance. Also, get the 2gb version of the 270x. The 4gb version is not really smart considering how the card won't take advantage of more than the 2gb version can provide even if you have the 4gb version.
