PC-First Build-Feedback
Hi Guys
This will be my first post and first ever PC-build and before i go ahead and buy any of the parts i have considered, i just want to get some knowledgeable input if i am on the right direction.
I'm aiming for a good solid gaming rig, that has the potential to OC, and play all current and future games on High settings. Aiming the budget below $1600AUD.
Note: i live in Australia, so prices for components will be different to those in other countries.
CPU: Intel i5 3570K
CPU cooler: Cooler Master Hyper 212 EVO
MOBO: Gigabyte GA-Z77X-UP5-TH Motherboard
Mem: Corsair Vengeance 8GB(2x 4GB) Dual Channel DDR3 Memory Kit
SSD:Samsung 830 Series 128GB 2.5" Solid State Drive
PSU: Corsair Enthusiast Series Modular TX 650M
GPU: Gigabyte GeForce GTX 670 (will put in a second card later)
Disc drive: Lite-On IHAS124 Internal SATA 24x DVD Buner Drive - OEM
Case Cooler Master HAF X
This build is a little over $1600AUD, so anything lower would be awesome.
So if anyone as any input or certain parts or recommend others, it would be much appreciated
Thanks
Your build is pretty good! i recommend a Evga 670Ftw card though rather than the gigabyte, considering the ftw is roughly as good as a standard 680, your coller should be good, also i personally prefer the asus p8z77-v boards over gigabyte z77 boards. one thing is, your power supply isnt good enough for SLI 670's get at least a 750W power supply.
Hope this helps.
thanks for the advice
