Okey, When i play games my game starts to lag and then it will freeze with a coloured striped screen and i need to restart my pc to fix it. I will in about a month replace 1 part in my system to a newer one but i dont now what may cause the problem and i would like to replace the part who is failing, i cant afford 2 and i do not have any other part to troubleshoot it i only have does in my system. So i really cant screw this up so any ideas of what it could be 1 got a couple of things i now its not and those are RAM memory and my screen i replace and check them and not overheating its okey temperature in it my parts is
CPU: AMD phenom II X4 955 With a Artic Cooling Freezer A30
GPU: AMD Radeon HD 6770
PSU: Chieftec NTRO 85+ BBC 550 C 550 Watt
Any more information about my system is on my profile
Please help me before i thrown my system out of the window any then cause a fire that will burn both me and my house I am guessing its my Gpu but i do not really know its only a guess
Sound to me that your overheating, what temps are your parts getting while your gaming? If they go above 85c - 90c I would looking into what’s causing the CPU/GPU to overheat. One more question for you, are you overclocking, because sometimes when you get a bad overclock on your GPU, when you crash it can leave and oddly striped image on your display.
GPU-z Is what I use for monitoring temps, just go on the "Graphs" tab and the temps should be in there. Secondly has this been happening since you got the card or did this just start occurring? Its possible that you have a faulty card.
its maybe a faulty graphics card as you suggest i will probably change it, the problem has been for a while and it was good in the beginning but i got the problem for about 1 year ago but then it was not a big problem only occured sometimes but now its its worse than ever right now i have it several times a day which is a record
From what I've gathered it probobly some components loose and when it heats up it moves exer so slightly and looses contact or something like that. What graphics card is it?
I cant see any bloated caps at all and it sounds like overheating but the Gpu is always around 55-60 Degrees celsius when i play so its not near to overheating and like i said earlier its not my ram, my best guess is Gpu and i will replace it soon.
