PC Component Compatibility
Hi, I'm about to upgrade my rig and giving most of the old components to my dad. I would love it if someone could just controll check the future systems and give some feedback.
My future system:
   PC Case: Lian li TU100 black
   Motherboard: MSI Z87I AC
   PSU: Silverstone SX600-G
   CPU: Intel Core i5 4670
   GPU: ASUS GTX DCMOC-4GD5
   RAM: Corsair Vengance 2x4GB (from old system)
   OS-Drive: Intel SSD 250GB (From old system)
   OS: Windows 7 home proffesional
My father's future system:
PC Case: Fraktal Design Core 3000 USB 3.0
Motherboard: MSI Z77a-s01
PSU: Antec VP450P
CPU: Intel Core i5 2320
GPU: MSI GeForce 210 1GB
RAM: Corsair Vengance 2x2GB
OS-Drive: Intel SSD 120GB
OS: Windows 7
Thanks in advance!
I'll just give you overall advice and plug it into pcpartpicker.com for part compatibility...
Nothing glaringly wrong there. Sometimes you can get weird compatibility issues between RAM and Motherboards, but it's pretty unusual in this day and age. I would second the advice to plug the components into PCpartpicker, or if you want to learn something, look up each individual Input/Output specification for each part (CPU socket type, PSU outputs, PCIe specification, etc) and verify it yourself.
ASUS GTX DCMOC-4GD5
I assume that's the GTX 970.
Looks ok for your system.
Your dad's system looks alright too, but just take out the GT 210 GPU.  That's probably going to be just as slow as Intel's HD 3000 stuff.
Yes it is a 970 (sry forgot to add that). We choose a simple GPU for his PC since the motherboard doesn't have built in graphics and the only demand he has is that it can run 2 digital monitors.
