Pc Case (Around $100)
Helloo,
i'm building a computer but i just can't choose a case.
I really like the Fractal Design Define R4 but then i can't choose the color.
Anybody that knows some nice cases, not to flashy and around a $100 budget
Thanks!
I have the Fractal Design Define R4 in black. It's extremely quiet but it's pretty heavy.
alright, are the stock fans enough or should i add more fans?
The NXZT Source 530 has a ton of cooling potential, both on air and on water (it's the same case as the Phantom 530 that wendell reviewed, but with a different exterior). Just make sure to put two fans in the front as intake.
Phanteks Enthoo Pro, it has more features and WC support than you can shake a stick at, best $100 case you can get IMO
They are good enough, but I got the Fractal Design Define R4 Blackout with Window ATX Mid Tower Case because I wanted a window and used the Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler instead of the processor's stock fan.
ok i'll check it out
ok thanks!
Yea NZXT is a great brand. This is probably the most popular computer case- http://www.amazon.com/dp/B005869IUY
The Corsair 230T is pretty good. It comes with LED fans but it can be a bit noisy.
Phanteks Enthoo Pro. Nothing even in 150$ bracket can beat it feature wise... I love Fractal Design, but Phanteks Enthoo Pro simply have everything. The only reason I have Fractal Arc Midi R2 is because nobody sells Phanteks in my country...
