Do you guys think this is a good build http://ca.pcpartpicker.com/user/Muckhhh/saved/KvkBD3
What is your budget?
What are you going to do with it
basically read out the guidelines first so we can get an idea of what are you doing with it.
Where is the GPU ?
PCPartPicker part list: http://ca.pcpartpicker.com/p/cw7sTW
Price breakdown by merchant: http://ca.pcpartpicker.com/p/cw7sTW/by_merchant/
CPU: AMD A8-7650K 3.3GHz Quad-Core Processor ($120.01 @ Vuugo)
Motherboard: Gigabyte GA-F2A68HM-HD2 Micro ATX FM2+ Motherboard ($60.50 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2400 Memory ($63.40 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($58.01 @ Vuugo)
Case: Xion XON-310_BK MicroATX Mid Tower Case ($25.99 @ Amazon Canada)
Power Supply: Thermaltake SMART 550W 80+ Bronze Certified ATX Power Supply ($64.99 @ DirectCanada)
Total: $392.90
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-11-14 22:40 EST-0500
The 7850k isn't going to be worth that much more than the A8 7850k, and you'll want a bit higher wattage PSU for a dedicated GPU down the line
And ya, you want 2400mhz RAM for an APU
Yeah, we really need to know what the purpose of the build is for, otherwise, if you are video rendering and editing, you are going to have a really bad day with the proposed build.
The CPU has a GPU Built in.
I am looking to do a little bit of gaming such as battlefield 4 cs go mine craft and games like that my budget is 400$
http://pcpartpicker.com/p/mDQKwP
PCPartPicker part list: http://pcpartpicker.com/p/mDQKwP
Price breakdown by merchant: http://pcpartpicker.com/p/mDQKwP/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($68.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.59 @ Amazon)
Motherboard: Gigabyte GA-F2A68HM-H Micro ATX FM2+ Motherboard ($45.99 @ Amazon)
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1333 Memory ($37.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($51.88 @ OutletPC)
Video Card: Zotac GeForce GTX 750 Ti 2GB Video Card ($99.99 @ Newegg)
Case: Rosewill FBM-02 MicroATX Mini Tower Case ($21.99 @ Newegg)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply ($31.99 @ Amazon)
Total: $387.31
Generated by PCPartPicker 2015-11-14 23:02 EST-0500
Yeah slightly cheaper but kicks the snot out of an APU based system any day.
Definitely.
Ditch the cpu cooler and spend money on better gpu. They can always buy it later on to get a higher overclock.
There was no better gpu for $120 so there is no point and the stock cooler is loud and crappy.
I won't buy a aftermarket cpu cooler on a budget pc build at first. Plus he needs some games to play.
He can buy a couple of games that he can play with his budget and the build if he goes for mine. There are many great games that are affordable and does not break the bank.
If I was going to get a budget cpu cooler I would get the be quite pure rock for $34
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V2326642&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
The Cooler Master Hyper 212 EVO is about $29 bucks on Amazon in CAD Dollars that I have shown. The Pure Rock is about $34 USD which makes it about $45 in CAD. The Cooler Master Hyper 212 Evo is an extremely highly recommended CPU Cooler.
I have them both but I think it is worth the extra $16 CAD or like I said earlier don't get a cpu cooler now and spend money on something else.
Well, here's my suggestion:
PCPartPicker part list: http://pcpartpicker.com/p/67PvrH
Price breakdown by merchant: http://pcpartpicker.com/p/67PvrH/by_merchant/
Motherboard: Gigabyte GA-F2A68HM-H Micro ATX FM2+ Motherboard ($37.98 @ Newegg)
Memory: Team Elite 8GB (1 x 8GB) DDR3-1600 Memory ($32.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: XFX Radeon R9 270 2GB Double Dissipation Video Card ($148.98 @ Newegg)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case ($36.98 @ Newegg)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply ($27.98 @ Newegg)
Total: $398.69
Generated by PCPartPicker 2015-11-15 06:52 EST-0500
