Pc build
hey guys what do you think of this build?
  • Asus M5A78L-M LX3,sAM3+
  • AMD FX-6300,sAM3+ (i thought i'd go with the stock fan to begin)
  • Corsair Vengeance 1600-8GB (2x4GB)
  • Western Digital Green 1TB - 3.5inch
  • Asus Radeon R7 260X DCII OC,1GB
  • Corsair VS 350W ( is 350 ENOUGH OR SHOULD I GO FOR cx 430)
  • Fractal Design Core 1000
  • Samsung DVR DL 24X,SATA (because you never know)
>would change the mb, a 6 core can be too much for those old boards
>wouldnt run an os off a green drive, way too slow. grab a wd blue
>cx430 are would be a great investment
>id personally grab a 750ti over the 260x
thank you!!! yhea i was hovering at the blue or green drive wondering what the diffrence was, now i know :p
what about the Asus M5A97 R2.0,sAM3+ as MB?
Go with the blue drive.
Asus M5A97 R2.0 is a good motherboard.  Don't get the LE version though.
Go with the 260x if the 750ti is not available.
