It looks good imo, i would try and get different ram, something a bit more known, in case you need to RMA or anything ( i dont have any experience with Kingmax, just speaking from general experience )
http://au.pcpartpicker.com/user/Freaksamcker/saved/2vHi Man, Its hard to build there. This would serve you better and be worth saving the extra money for .
Between the prices and the lack of options , Its freaking crazy . Now they can cheap out with a stock cooler ( but they are noisy ) get a cheaper case if possible and maybe get a graphics card with 1 gig instead of 2 ( if using only one monitor ) which might bring it back inline with budget . I would even get a cheaper cpu like a 6100 .
i been running the stock fan since feb and its doing a pretty good job, its only now starting to loose its efficiency (using pre applied compound) and the noise of it..well i cant hear it...probably cos i got a antec 1200 v1 with 6 fans going lol. (been on 24/7 pretty much, the odd restart and about 4 days turned off when i was away)
i got a 650ti 1gig and to be fair it does pretty good, it doesnt like doing stuff on ultra but at medium its fine @ 1920x1200.
So those two cutbacks as you say wont really effect things too much.
