I have 3 possible builds but can not decide on which one.
I will be build the one that is the best in 2 weeks time.
http://uk.pcpartpicker.com/user/mike1234/saved/3vmu
http://uk.pcpartpicker.com/user/mike1234/saved/3uDD
http://uk.pcpartpicker.com/user/mike1234/saved/3jG3
Thx in advance
Edit: Also this will be for gaming
#2 cause my coin only has two sides.
I think the second build is best, though I don't think the network card is necessary. The 990FX Sabertooth already has a gigabit ethernet, so it should be decent.
I like this much better: http://uk.pcpartpicker.com/p/2FfL2 because you get a Gtx 770 and 120gb ssd compared to the 760 and mechanical hard drive. You also loose very little on this motherboard compared to the sabertooth in features. Also you know that these motherboards have on board Ethernet at the same speed the Ethernet card you have added has right?
None. I don't like at least one thing in each build.
1. 600w PSU probably won't work for SLI upgradeability.
2. Cheap 750w PSU has 4 +12V rails. Yes, it's gold rated, but having so many smaller rails usually indicates a cheaper overall build quality.
3. Intel's a bit expensive for the budget.
Here's what I'd recommend: http://uk.pcpartpicker.com/p/2FkXH
AS5 isn't really needed. The paste that comes with the Hyper 212 works fine. AS5 may drop temps 1-3c, but I don't think it's worth the extra money.
m5a99fx pro R2.0 is cheaper, and still a great board even if you're overclocking.
1600mhz with CLS9 is perfectly fine for gaming.
Added a 120GB SSD. Install an OS onto here, and maybe a game or two. This will make your daily usage very snappy.
Changed the PSU to a high quality XFX power supply. These use all Japanese caps and are designed by seasonic.
