I was wondering if this build is worth it or could you do better for the price. I am just a dreamer right now. I really want a PC for gaming and editing. I want to be a youtuber. Please help me. http://secure.newegg.com/WishList/TemporaryWishList.aspx
Thanks for linking me to my own wishlist.........
Use this : http://pcpartpicker.com/parts/partlist/
If he gives us that, it will also be empty.
This looks oddly familiar....
Oh thanks! Here you go.
http://pcpartpicker.com/p/1bScZ
Drew for $750 dont build a apu instead get the amd radeon 7580 with a amd fx 6300
Fighter. WOW. didn't look at that one is this apu one that you would recomend? Thanks
http://pcpartpicker.com/p/1bSXW to match your $680 add a 7770 (better for gaming, or really in general) or 650ti (better if you're using adobe premier for editing)
but what's your max budget?
I don't Know right now i have no money haha but probably $800. If you want make me a build that you would buy. I just want the most out of my money.
what program will you be using for editing, because that will tell you the graphics card you'll need
I have no idea
