PC Build
Hey guys...im planning to build a pc, I just wanted to know if all these parts are perfectly compatible.. you can also suggest some replacements that fit in the range... THANKYOU.
Intel Core i5-3570 CPU
Sapphire AMD/ATI HD 7770 1 GB GDDR5 Graphics Card
MSI ZH77A-G41 Motherboard
Corsair Enthusiast Series Modular TX650M - 80 PLUS Bronze Certified 650 Watt PSU
WD Caviar Blue 500 GB Desktop Internal Hard Drive (WD5000AAKX)
Asus DRW-24B5ST DVD Burner Internal Optical Drive (Black)
Corsair Vengeance DDR3 4 GB (2x4 GB) PC RAM (CMZ8GX3M1A1600C10)
NZXT Source 210 Elite Mid Tower Cabinet
Budget?
They are all compatible but a FX6300 and 7850 would be a better choice if you're using this for gaming mostly.
Pip is correct.
6300 nnd 7850 brother. Could probably actually do a 965/7870.
Well the AMD FX-8350 is 20$ cheaper and it performs 10% more than the i5 3570k just look at Logans vid:http://www.youtube.com/watch?v=eu8Sekdb-IE
A good motherboard for that s the Gigabyte GA-990 AM3+
A more expencive video card is the 7870 HIS but its really good chak Logans review:http://www.youtube.com/watch?v=UkOZhwutP-o
Im very sorry if you hate AMD and best luck with your build! :)
thnx for the feedback guys... im perfectly fine wid amd fx 6300 and radeon 7870
about 700$ ..thanks
