PC build
Hi!
Would love some ideas around my next build, this will mostly be a gaming PC, may use some rendering tools but not to the extent where it would be necessary to get an i7. I might change the PSU to the thermaltake 850 for adding another 7970 later on. If you find something that should be upgraded / downgraded please tell me.
Creative Sound Blaster Fatal1ty Recon3D
HIS Radeon HD 7970
G.Skill 8GB DDR3 1600MHz (2x4)
Thermaltake SMART M750W
Kingston HyperX 3K Upgrade SSD - 120 GB
2TB Seagate Barracuda 7200rpm SATA 6Gbit/s
Fractal Design Arc Svart
Intel Core i5 2500K 3,3GHz
Corsair Hydro H100-serien
ASRock Z77 extreme4 ATX
All this lands on 12,251 swe kronor which equal 1854,05$
For reference on prices i'm using www.proshop.se
Thanks.
go with a diffrent sound card!!!! I have it and its only ok (IM using 5hz-80,000khz  http://www.sony.co.uk/product/extra-bass-dj-headphones/mdr-v900hd/technical-specifications) and this card doesn't perform like it should for music im using 24bit Flac files and upsampling to get it close to right.
I have to say that if you love music these headphones sound like a choir of angels when lisining to LP's through a audio receiver
and plz get 2x4gb ram
budget?
