PC Build Under $550
It would be great if anybody could put together a PC build for around $550. I will be using it for light gaming (Skyrim on Medium.) Thanks.
https://docs.google.com/document/d/1SpXDEcSPD9OvrFvYG7ZoK12AUra9GZvmBwgbF2zoydQ/edit?usp=sharing
its $603 but i it will run everything on kick ass levels  also the link i sharred is a doc with all da links
Thanks
For the love of God please use PC Part Picker next time. I'm not trying to be mean but it makes it incredibly difficult.
http://pcpartpicker.com/p/RfWhmG
Here. This will do nicely and will be much faster than the rig built in the Google Doc's link.
ty,about to the same thing.
Yeah. Thanks
http://pcpartpicker.com/user/Freaksamcker/saved/7TdxFT Here is 1 that is  close to rock bottom cheap as you can get. Running stock or a light oc is fine with good airflow. I do actually prefer Derkeigor's build but this will get the job done aslong as you dont get crazy with it.
