http://pcpartpicker.com/p/3AnN7
Anyone have any better builds within the same price range? Thanks. I would be playing some games that could run fine on the APU. I could make do with a 500GB HDD. Thanks for your help.
Nevermind what I said about the 500GB HDD
I have no issues with both of my 1 tera blue drives. If I were you I would stick with that. When it comes to memory of any kind it is better to have too much then too little.
http://pcpartpicker.com/part/gskill-memory-f317000cl9d8gbsr change the ram to that and then i think your good to go :)
Here you go, beefed up your APU and your motherboard now has a heatsinked VRM and changed the power supply for a corsair, it should have better build quality than the EVGA
http://pcpartpicker.com/p/3FjBi
i prefer faster RAM for an APU based system
http://pcpartpicker.com/part/amd-memory-r938g2130u1k
Well thanks guys. With your help I put together this ---> http://pcpartpicker.com/p/3FGuM
Looks good.
