PC Build Pictures
Here are the specs:
AMD A-10 5800K (overclocked to 4.2)
AsRock FM2-A75 Pro4 Motherboard (6 USB 3.0 and it's hella easy to overclock)
8 GB G.Skill Sniper Series RAM 1866 Mhz CAS 9 (overclocked to 2133)
Corsair H60 Liquid Cooler (2 fans in push-pull) Temps: Idle: 31 C Load: 54 C
Western Digital Caviar Blue 500GB HDD
RAIDMAX 500w 80 Plus Bronze PSU (cables shorter than T-Rex arms)
Corsair Carbide 200R Case
anyone know how to post pictures from my desktop?
As far as I know, you need to upload the picture first to a host such as imgur. Can't post a image from your files, only via URL's with that little image of a tree above the text box.
ok thanks man
oooh raidmax...?
dunno bout that..
otherwise a good build, looks pretty identical to my budget build
