Pc build idea
Hi
I wanted to build a $600ish gaming machine I’ve looked at different vids and come up with these parts so far. I already have a segate barracuda 1tb with win7 on it. and a dvd writer/reader.
GPU:EVGA GeForce GTX760 SuperClocked 2GB GDDR5 256bit, Dual-Link DVI-I, DVI-D, HDMI,DP, SLI Ready Graphics Card (02G-P4-2762-KR) Graphics Cards 02G-P4-2762-KR
Motherboard:GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
CPU:AMD FD8320FRHKBOX FX-8320 FX-Series 8-Core Black Edition
CPU cooler:need help deciding (needs to be rather cheap though)
RAM:Kingston Technology HyperX 8 GB (2x4 GB Modules) 1600 MHz DDR3 Dual Channel Kit (PC3 12800) 240-Pin SDRAM KHX1600C9D3K2/8GX
PSU:Logisys Corp. 550W 120mm Ball Bearing Fan with PSU ATX 550 Power Supply PS550E12BK, Black
Is anything missing (apart from the case which i will sort out)
Also if anywhere i can get some money back as i am on a tight budget would be great if you can point them out!
Many thanks!
Hey if you're looking for a cheap good CPU cooler take a look at the Zalman CNPS5X Performa CPU cooler. Also for the CPU if you're only going to game take a look at the FX 6300 it's pretty much the same performance as the 8320 but it only as 6 cores which won't make a difference in gaming. Good luck with your computer build :)
