First off what country are you in?
Second, what are the end results you hope to achieve with the computer?
If you're in Europe it's likely best to go AMD on your GPU... as they're normal prices over there and a R9 270x is linear to a GTX 760... both will play @ ultra 1080p easily (not at 1440p)... In the US, the AMD's are marked up from litecoin miners, so the 760 would be a much better option here...
I'd get the k model i5 chip so you can overclock unless you're really opposed to it (of course without knowing your market I couldn't tell you how much more)... the Z87 chipset is awesome for OC... If you aren't overclocking I'd stick to a Micro ATX form mobo...
Also keep in mind that SLI is expensive and is really only recommended if you need more performance than the flagship models can provide... I do not recommend buying a 760 to have something right now and then buying another 760 later. For the same price you could have had a 780 or R9 290X which will vastly outperform 760 in SLI. If you're worried about performance later, I'd look into the 770 or 280x, whichever is cheaper.
About the mobo, ASRock makes a decent mobo but uses cheaper components than Asus, MSI, and Gigabyte. I prefer Asus mobo's because I've used them forever and never had a problem with them. If it's $5 difference between a main brand like Asus and MSI vs ASRock, I'd get the Asus or MSI...
It may stretch your budget to get what you want, but it's a lot better than breaking you bank account for something you know you won't be happy with. GPUs are expensive.
As far as SSD vs HDD, SSD may be the most noticeable performance boost you can buy besides a good GPU... they're FAST
You also didn't list a CPU cooler, which is a necessity when overclocking, and useful still otherwise. Stock coolers are generally coasters.... (AMD's moreso than Intel's... but still) You're two biggest investments in a computer will be your GPU and CPU... protect them... especially if it only costs an extra $20-30...
All I can speak is what I would do, and that's what I would do...
