PC build help
Okay I'm building a gaming pc instead of going with next gen consoles...
I'm thinking of spending about 500 euro - 650 euro...
I've done my research and I THINK I have my final build...
CPU: AMD athlon II x4 750k http://www.dabs.ie/products/amd-athlon-ii-x4-750k-black-edition-3-4ghz-fm2-4mb-100w-8F06.html?src=15
or AMD FX 6300http://www.dabs.ie/products/amd-fx6-6300-black-edition-vishera-six-core-am3--3-5ghz-14mb-95w-8BXH.html?src=15
or AMD FX 8320 http://www.dabs.ie/products/amd-fx8-8320-black-edition-vishera-8-core-am3--3-5ghz-16mb-125w-8BXG.html?src=15
RAM: Kingston hyperx 8gb (2x4)http://www.dabs.ie/products/kingston-8gb--2-x-4gb--hyperx-ddr3-1600mhz-dimm-240-pin-cl9-xmp-grey-7JT1.html?refs=468550000-418700000&src=3
HDD: 1tb Seagate barracudahttp://www.dabs.ie/products/seagate-1tb-barracuda-sata-6gb-s-64mb-7200rpm-hard-drive-7XD5.html?src=15
Case: Cooler master k-series 280http://www.dabs.ie/products/coolermaster-k-series-k280-usb3-0--atx-case-8RCZ.html?src=15
Cooler: Cooler master 212 hyper evohttp://www.dabs.ie/products/coolermaster-hyper-212-evo---4-heatpipe--tower-cpu-cooler-8K32.html?src=15
GPU: I'm pretty unsure between the new r9 270xhttp://www.overclockers.co.uk/showproduct.php?prodid=GX-328-SP or hd 7950 http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HS because the 7950 comes with Bioshock infinite, crysis 3, and an amd gold rewards code for 250 euro but the r9 270x is 175 euro
Mboard: I'm not to sure any ideas?
Any help would be very much appreciated!
Thanks.
P.S. sorry for the extremely long post.
The r9 270x is just a rebranded 7870 so the 7950 will preform a noticable amount better so i would go for that. the fx6300 or the 8320 are both great
Go for the 7950 and the 8320. Everything else seems good.
A good motherboard would be the Asus M5A99FX or M5A99X boards. Really nice boards for the price. Also, what PSU are you going with? It is every bit as important as all of your other components.
My PSU is a 600w modular psu from corsair http://www.dabs.ie/products/corsair-600-watt-builder-series-cx-600-modular-power-supply-8GFV.html?src=15
Btw my motherboard is the ASrock FM2A75-Pro4 http://www.dabs.ie/products/asrock-fm2a75-pro4-fm2-amd-a75-ddr3-atx-8NNQ.html?refs=48620000-486690000-42180000&src=3
any thoughts?
Since you live here in Europe, I've used the Deutschland on pcpartpicker
Take the Asus M5A97 R2.0 if you won't be overclocking (or just a little bit)
Take the Asus M5A99FX if you will be overclocking (pretty good-very high overclocks)
link
The Hyper 212 EVO wasn't there on pcpartpicker, so you have to buy that somewhere.
Bye,
J
