PC Build Help!
Hey guys and girls of TekSyndicate. I am planning on building my first PC in the upcoming months. Ihave taken apart a few old pentium 4s so I kind of know what I am doing. I am in the U.S. and have a 600-700$ budget. I am mainly going to be using it for gaming and just everyday use but in the future I might start doing some rendering. I have two different potencial set ups but i am not sure if they will be good for what I want so if you guys could give me some help it would be greatly appreciated. here are the parts for the two potencial set ups.
AMD APU set up:
-AMD A10 6800k Richland APU 4.1 Ghz
-corsair CX500m 500w 80 plus bronze certified PSU
-MSI FM2-A85XA-G65 Motherboard
-G.SKILL Ripjaws X Series 2 x 4GB DDR3 1866 pc 14900 Ram
-Raidmax Seiran Case
-Western Digital WD Blue 1TB 7200 RPM 64MB Cache Sata 6 Gb/s 3.5 in mechanical hard drive
AMD Fx set up
-AMD FX 6350 Vishera 3.9 Ghz
-ASUS M5A97 R2.0 Atx motherboard
-Coolmax ZU series ZU-600B 600w 80 Plus Bronze Certified PSU
-EVGA 02G-P4-3658-KR GeForce GTX 650 Ti Boost Superclocked 2Gb 192_Bit GDDR5 PCI Express 3.0
I already have a couple of optical drives from those pentium 4s so i dont need those, and I am just going to pick up a well reviewed monitor. Also I am not including a mouse and keyboard into the budget. If you have any recomendations for other parts, if I should change some of the parts, or change the hole set up just tell me. Thanks again!!
imo http://pcpartpicker.com/p/1mu5e
or http://pcpartpicker.com/p/1naoM
Thanks for the suggestions.
http://pcpartpicker.com/p/1nbpj
...don't think i forgot anything, your second one looks ok, except for the psu
OK, thanks
