Pc Build help/suggestions?
HI im going to build a pc here are the specs:
AMD Fx6300 ($145 sale original:$195)
Heatsink: CoolerMaster Hyper EVO 212 ($35 Original $49)
Mobo: Asus M5A78L-M-LX-V2 AMD Mainboard - AM3+ ($80)
RAM: Kingston (KHX1600C9D3B1K2/8GX) 8GB DDR3-1600 CL9 ($100 Original $108)
GPU: XFX Radeon 7750GDDR5(Planing to upgrade soon)
PSU: Corsair CX500
Case: Bitfenix Prodigy Black($100 Original $110)
This is my PC build i will be getting the money in a few weeks i got the Power Supply and upgrading the GPU after i got my new build and will salvage a 1TB HD from my current rig. Oh and the prices are in AUD since I'm from Australia and the prices that they offer from which i am getting the parts from. Any Suggestions to improve on my new build but i will not be spending another cent or any drawbacks that affects gaming performce.
the bitfernix prodigy is a mini itx case, im highly doubting that you could fit a micro atx board in there..?
i would say go with a normal ATX formfactor trow the FX6300 on a Asus M5A97 R2.0 mobo.
yeah thinking of going with a normal atx case wont be doing any overclocking because i just want it as it is. thanks for the better motherboard option i may consider getting it over the other one.
Yep, you'll need an m-atx case. Also I would reccomend either getting an hd7870 (or an hd7950 if you find it for the same price) or for a little cheaper one of the new r7 260x graphics cards. Everything else looks fine to me.
