I've recently started to learn about builing PC's specifically gaming rigs. Now I was wondering what is the best possible build I can get for around 375-450 USD. Any help or input will be apreciated.
Start here and work your way up.
https://www.youtube.com/watch?v=5NoONgFEUo8
It's a bit cheaper then you suggested but you could do a different motherboard and cpu combo and get 7870
Heres an A10-5800K build, shipped to your door at $453
http://pcpartpicker.com/p/rKxe
Thats awsome! I wish all the builds on here had the parts list like that.
Yeah partpicker is really useful. I ordered the same build as that one last night except I sprung for a Thermaltake Chaser MK-I which I got for ninety bucks a few weeks back. If you aren't gonna do much more than game you could get less memory
Nice! 1 more questionn: So you dont need a video card on this build?
Here is the same thing but with faster memory but only 8 GB of it. It will safely run at 2400 MHz but I believe you will have to clock it up in the BIOs but thats pretty typical
http://pcpartpicker.com/p/rLHB
Edit:
The video card is actually built into the CPU with these types of builds. It uses the system memory to run the graphics and that why I am reccomending the fast stuff
Great I think I found my first build!!!!
Awesome man, glad I could help. I based it on the $350 build Logan did awhile ago and just did some tweaking
Thank you so much! This really helps!
