Hello! Well I'm looking for a gaming pc. I usually play League of Legends, and Counter Strike: Global Offensive, among others. I just need the rest of the PC already have (monitor, mouse and keyboard, etc.). I live in Portugal and of course I use the euro coin. Frankly I enjoyed playing between 150 to 180fps or more. My budget is 500-600 euros. If anything missing please tell
Okay, why? Do you even have a monitor that can display more the 60fps? I'm Curious as usually 60 fps is the cream of the crop so to speak. To get 150 fps on games, not just the ones you listed you'd need more then your budget can handle.
i know its in the region France but it is in euros. You could go down to a 7770 if you set the graphics to medium, turn off anti-aliasing and disable hud animations for LoL
Here's what I came up with at the top of your budget, you could always find deals but with that budget thats what I would do. Good luck! http://pcpartpicker.com/p/2rbja
