hey i just built my new pc but no display is on when i turn on the computer all the connectors are connected i think and the my hard drive is a used hard and there is data on the hdd 1tb and also there are no beeps coming out when i turned the computer on relpy ASAP.
I would say double-check your power supply connections to the motherboard. Make sure the LED on the motherboard is lit up when you turn on the power supply. Also make sure you put in the 12 V connector for the CPU and GPU apart from the main 20 pin rectangular cable otherwise it won't power up at all. You could try taking all hardware out of the case and shorting the front panel power pins to see if the case power button is faulty(very rare). Short the green and black cable power pins on your 24-pin/20-pin rectangular PSU power connector and check if the PSU fan is working by placing your hand near the fan exhaust. Try this and report back.
