I'm a PC gamer and have been for a great many years. My son in law is a hardened Sony Playstation gamer. Like a dripping tap over many years I have finally persuaded him to have a look at PC gaming.
Not sure why but cost of games and the fact he will be getting this Pc fro free may have had something to do with it
The rules are as follows, it's got to hook up to his plasma TV. He has got to be able to play from his couch.
Most of the hardware is easy because I have recently upgraded so he is getting some of my old stuff.
CPU: AMD 8150, Cooler: Noctua NH-D14, MoBo: ASRock FX990 Extreme 3, RAM: G.Skill 8Gb @ 1600MHz, Storage: Intel SATAII 80GB SSD + 500GB Mechanical, G/Card: Powercolor 6870, Case: CM Scout, PSU: Corsair HX750W,
Both the CPU and G/Card are a little weak but should be fine for a first gaming rig. The tricky bit is outputting to the Plasma TV and then controllers! I may have to pick up an optical drive, I have not used them for some time in my own builds.
I have looked at the back of the TV and it has an old school VGA D-sub connector plus hi fi type sound. There is HDMI but will all of the other stuff connecting with HDMI I think he is running out of ports. More to the point I have the VGA cable + the DVI to VGA adapter.
I was thinking of picking up some simple wireless bits, Keyboard and mouse and an XBox controler... Thing is do these things have any range limitations? Am I missing anything? Is there something a console gamer would want or expect from a gaming PC that I have over looked???
I think once I have explained Steam to him he will never look back, especialy when he sees the price of games :)
