I see, you have a point. Thanks for the corrections!
+1 for this build. You should be more than happy with this build for what you are doing.
+1.
Also, you may want to look into an external DAC solution to try to eliminate all interference. Also, the back audio port will almost always be better than the front one, due to the audio header being susceptible to interference.
Thanks for the input to all
Hey caveman, one small suggestion. Switch out the PNY SSD for a M500. Its $110 on NCIX and $115 on amazon. Quite a nice little SSD for that matter.
