After many weeks of research and looking around and getting advice from multiple people, I have finally compiled the list of parts that I wish to have in my PC.
This is my first build, and I'm only 95% sure about what I'm doing, so I figured I would check with the kind people of the forum to see if you guys notice any incompatibilities. I would also like to hear what you think about the parts I picked. It's a semi-budget build, so it's obviously not the best, but definitely a start.
Here are the parts:
Case: Antec Nine Hundred Two V3 ATX Mid Tower - http://pcpartpicker.com/part/antec-case-ninehundredtwov3
CPU: AMD FX-8320 3.5GHz 8-Core Processor - http://pcpartpicker.com/part/amd-cpu-fd8320frhkbox
CPU Cooler: Cooler Master 212 EVO (will upgrade when I have the neccessary funds) - http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2
MotherBoard: Asus M5A99X EVO ATX AM3+ - http://pcpartpicker.com/part/asus-motherboard-m5a99xevo
RAM: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1333 - http://pcpartpicker.com/part/gskill-memory-f310666cl9s8gbxl
HDD: Seagate Barracuda 500GB 3.5" 7200RPM (will probably get a small SSD later: again, money) - http://pcpartpicker.com/part/seagate-internal-hard-drive-st500dm002
GPU: EVGA GeForce GTX 660 2GB (can't afford the 680:( ) - http://pcpartpicker.com/part/evga-video-card-02gp42662kr
PSU: Rosewill 750W ATX12V / EPS12V - http://pcpartpicker.com/part/rosewill-power-supply-hive750
The PC will be used mostly for gaming, recording gameplay, and editing/rendering videos. I think it should be able to accomplish that.
Thank you to anyone who helps!
