Hey,
http://www.scan.co.uk/savedbasket/a335777c35f8407fa26c8e3ff81a2b79 Total:443 pounds
I was wondering if this is a good pc for playing games listed in the title
I have some questions
1)What kind of fps will i get?
2)will i need to upgrade the athlon any time soon?or is it ok to use in this build?
3)can you go any cheaper than this?
i will be running steam os when it releases saving money on buying an os and i will not need a hardrive
thanks-lee
Maybe spend the extra thirty quid and get a MSI 7950 and upgrade the PSU to 500w, you wont need it but it's better incase you want to overclock in the future.
Other than that you will have a more than playable experience if you upgrade to a 7950.
http://uk.pcpartpicker.com/p/1LtbO
CPU: AMD Athlon II X4 760K 3.8GHz Quad-Core Processor (£60.77 @ Ebuyer)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard (£53.22 @ Dabs)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory (£52.99 @ Amazon UK)
Video Card: PowerColor Radeon HD 7950 3GB Video Card (£176.99 @ Ebuyer)
Case: Zalman Z5 Plus ATX Mid Tower Case (£38.99 @ Novatech)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£48.96 @ CCL Computers)
Other: Aula Bundles Blue LED Keyboard+ Mouse Illuminated Backlit Multimedia Gaming Combos (£37.00)
Total: £468.92
